turn signal problem
Old Dec 27, 2005 | 02:07 AM
zorbit's Avatar
turn signal problem
It all started when my passenger rear turn signal light went out. When I went to replace the bulb the socket was all melted and charred. I bought a new socket and bulb and realized that the turn signal works when the lights are not on. When the lights are on just the passenger side rear tail light doesn't work. I don't know what to do and need help before I get a ticket.
Old Dec 28, 2005 | 04:41 PM
87and 93birds's Avatar
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
bad or wrong bulb is my guess.
Old Dec 28, 2005 | 10:52 PM
zorbit's Avatar
the bulb was installed/indexed in the right place. i'm thinking about the wire connection.
Old Dec 28, 2005 | 11:00 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I have a hunch that you twisted the wires together and used electrical tape...
Did you solder and heat shrink each connection? Especially since moister surrounds them?
Old Dec 29, 2005 | 12:33 AM
zorbit's Avatar
yeah, this is what i did! but i just pulled out wires with the same color together.. is that bad?
Old Dec 29, 2005 | 10:33 AM
Dirtbik3r's Avatar
If I remember correctly, there are two wires that goto the socket. I really do not think it matters which color is correct if there are only two wires. Try doing a propper wire repair and if that doesnt work, I'de say check your ground wires. It's hard to guess at these things without something to go by. Do you have a volt meter that you can use to take some voltage drops? That would help... Anyway, Goodluck and I hope you find the problem.
Old Dec 30, 2005 | 12:12 AM
zorbit's Avatar
i checked it together with my friend. wire was burnt! melted inside! i had it changed! better!
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
