temperature guage
Old Dec 31, 2005 | 12:40 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
temperature guage
the needle of the guage is stuck over 260 degrees.. i took off the bezel and flicked the needle, and it went back to being loose. Then when i turn the car back on, it jumps to 260. do i need a new guage? or do i need a new sensor?
Old Dec 31, 2005 | 12:25 PM
dariat's Avatar
I had the same thing. Not sure if it has always gone to full and just started getting stuck or what.
What i did was pull the gauge our and bent the lip up to vertical where the needle touched at top and botttom ( sometimes got stuck at the bottom after getting unstuck at the top ).
I also happened to notice my needle was loose. Super glued it down when i had it out. ( think it might have been the fact that the needle was loose) It was coming loose from the black circular part.
Worked for me, might work for you.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
