Fan works in all positions but high
Old Jan 3, 2006 | 12:32 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I did a TPI wiring and engine swap in my 91 RS a while back and there's one thing that's been annoying me to death, my fan blower works on all settings but high. I can't find what wire is used for the high setting, anyone know what i should be looking for here? The harness is from an 89 TPI Trans Am, dash wiring is still the stock 91 RS.
Old Jan 3, 2006 | 10:19 AM
Vader's Avatar
The fan is operated through the resistor array in the three lower speeds, and through the relay on high speed. The relay has a power source directly from the battery via a fusible link. Check the relay and fuse link.
Attached Thumbnails Fan works in all positions but high-238blowercontrols.jpg
Old Jan 3, 2006 | 11:55 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Also check right above where the heater Core comes thru the Firewall There is a big red wire with a piece of crap grey connector That suplies the power I had the same problem....I could get everything but High make sure that connection it is good and tight
Azrael91966669
25
Jun 20, 2017 04:04 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Leggman1
Aug 6, 2015 04:15 AM
