Headlight motor not working
Car: 1986 Pontiac Firebird
Engine: Modified Chevy 350
Transmission: 700-R4
Axle/Gears: GM 10 bolt 3.73 gears
I am having a problem with the drivers side headlight motor on my firebird. When I the car the drivers side motor was shot. I replaced it with a new one. And it still does not go up. I replaced the 2 headlight relays and checked all the wiring. Still nothing. None of the fuses are blown in the fuse block. What could be causing this.
Jay
Jay
Do the headlights come on when you turn on the switch? Also, can you hear the motors working and the lights just wont come up maybe the gears in the motor case are stripped out and there is an easy way to fix that (if you can hear them working). 3rd and 4th generation Firebirds are notorous for having headlight gear and motor problems.
The passenger side does work and i can hear that working. But I replaced the one that did not work at all with a brand new motor that I purchased at my local speed shop and still nothing. No sound is coming from it at all. Which probobly means that there is no power getting to the motor at all. So what could that be. Could is there more than 2 headlight relays or one that I could have missed.
Jay
Jay
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
there are actually three relays, one on each side of the car near the headlights, and one beside the radiator on the passenger side as well.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
