85 Z28 inst. lights
Old Jan 25, 2006 | 07:01 PM
Z 28 Mike's Avatar
Car: 1985 Z 28 camaro
Transmission: 700 R4
85 Z28 inst. lights
Hi, I just signed up today on this board so I can get all of my questions answered. My first question is how do I go about replaceing all of my inst, lights?
Old Jan 25, 2006 | 10:07 PM
Vader's Avatar
If all the lamps are not working, the bulbs themselves may not be the major problem. The INST LPS fuse in the panel or the light dimmer control in the light switch may have failed.
If some of the instrument lamps are out, the fuse and dimmer circuit are probably working, and you need to replace a fistful of bulbs. Get a box of #194 lamps and start unscrewing.
You will need to remove the instrument cluster. The lamps are in bayonet style sockets on the rear of the panel.
You can remove the upper dash pad to gain access to some of the lamps, but it is just as easy to remove the cluster and get to all of them.
Old Jan 26, 2006 | 01:09 PM
Z 28 Mike's Avatar
Thanks, that helps, but is there any trick to removing the inst. cluster?
Old Jan 26, 2006 | 01:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here are some how-to's:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Old Jan 26, 2006 | 02:01 PM
Z 28 Mike's Avatar
Thanks, but what I ment was things like removing the steering wheel, what types of nut or screws to remove the pad with etc...
Old Jan 26, 2006 | 02:04 PM
JamesC's Avatar
The first post in the link deals with cluster removal.
JamesC
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
