no tail lights
Old Jan 25, 2006 | 11:44 PM
darkmage's Avatar
Car: 1991 camaro rs
Engine: 355
Transmission: tci streetfighter 700r4
no tail lights
every time i turn my headlights on my car blows the tail fuse then i have no tail lights no gauge lights no parking lamps nopower to the acc ports on fuse box! i deperatly need some help ii have no idea what is goin on. thanks
Old Jan 26, 2006 | 01:18 PM
darkmage's Avatar
Car: 1991 camaro rs
Engine: 355
anybody? i need the car tonight thaks
Old Jan 26, 2006 | 04:15 PM
Firebat's Avatar
check out your bulbs, its possible that when a lightbulb goes out, the wire inside of it can cause a short. Otherwise you have an exposed wire touching the chassis/metal of the car somewhere. See if it does it when you turn on just the parking lights. That way you can narrow it down to the parking lights or the headlights. Its also possible you have a bad switch.
Old Jan 26, 2006 | 06:43 PM
Meinherr49's Avatar
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Blown Fuse
Or Maybe the Wrong Amp Fuse for the Tail Light Circuit .
Old Jan 26, 2006 | 06:45 PM
Firebat's Avatar
should be a 20 amp fuse for the taillight fuse
Old Jan 27, 2006 | 12:54 PM
darkmage's Avatar
Car: 1991 camaro rs
Engine: 355
the correct fuse is in there. i guess i gotta go wire hunting!
Thanks, DarkMage
Old Jan 7, 2007 | 09:34 PM
Clark's Avatar
Car: '88 IROC-Z
Transmission: 5-speed
sorry to bring back a year old topic, but I have this same problem. I have no gauge/HVAC lights, taillights, or park lights. It blows the tail fuse every time I turn on the park light, or headlights...
BTW, my headlights still turn on and function properly.
Old Jan 11, 2007 | 07:24 PM
miklswab's Avatar
Car: 85 iroc clone
Engine: Carb'd 350 4 bolt main
Transmission: 700r4 2200 stall
Axle/Gears: 9 Bolt BW 3.45
exact same problem as clark
Old Jan 11, 2007 | 09:30 PM
Clark's Avatar
Car: '88 IROC-Z
Mine turned out to be a the brown power wire from the headlight/dimmer swtich that ran to the stock stereo. My brother mistook it for a ground wire, and spliced it into the existing ground. So every time I turned on my headlights, it would short it out and blow the tail fuse.
I got the charts to trace all the dash lighting wiring from alldatadiy.com.
Old Oct 10, 2007 | 09:24 PM
Falcoms's Avatar
Car: 1990 Mazda RX-7
Engine: 1308cc 2 rotor wankel
Transmission: 5 speed turbo II trans
Axle/Gears: 4.33:1 GTU-S rear end
Re: no tail lights
Okay, here's a good one then. Still related, but slightly different. I have no side marker lights, taillights, or brake lights. Headlights and turn signal are still good, but the front turn signals get bright, but don't blink, and the rear lights don't turn on at all. 20A fuse is installed and still good. Any hints appreciated.
Old Oct 10, 2007 | 09:39 PM
Firebat's Avatar
Re: no tail lights
Bad parklight/headlight switch, or maybe bad wire/connection from the parklight switch.
Old Oct 10, 2007 | 09:45 PM
Falcoms's Avatar
Re: no tail lights
but what about the lack of brake lights too, does that also power/complete the brake light switch circuit?
Old Oct 10, 2007 | 09:47 PM
Firebat's Avatar
Re: no tail lights
oh, didn't see the no brake lights. Might have to think about that one, I'll look at a wiring diagram.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
