high beam switch
Old Jan 26, 2006 | 07:32 AM
wheelstandin87's Avatar
Car: 87, 88 and 89 Iroc-Z
Engine: 305, and 350
Transmission: 700R, and T-5
Axle/Gears: 3:23 POSI
high beam switch
My friend needs a high beam switch and he has airbags. He needs to pass MD. Inspection and it doesnt work. Can this be relocated from the stock location to a switch. That way he doesnt have to have the airbag deflated or what. Becuase that costs to much.. And has anyone else gone through this problem?
Old Jan 26, 2006 | 08:57 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You don't deflate airbags, what he needs to do is pull the fuse for the airbag and disconnect the yellow wire under the steering column, this way it won't deploy if something grounds out. Then drop the column and replace the switch the correct way, since he has to be messing with the wiring on the column anyway.
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
