camaro turning off when brake is pressed for a while
My camaro seems to turn off when pressing the brake for a while! Pep boys , and auto zone have no idea (they seem to know nothing) anyone have an answer id appreciate it--
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
NOW THAT's WHAT I CALL STOPPING THE CAR !
<CENTER><B>Two things to check for.
Make sure you do not have a brake light short.
Make sure you do not have a vacuum leak in the
brake booster system.</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
<P>
.TO
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
A mechanic
Definetly steer clear of Pep boys. I have had bad experiences, as well as many others on this site.
Do u know any local places you feel comfortable bringing it to?
.Definetly steer clear of Pep boys. I have had bad experiences, as well as many others on this site.
re:
I just got it and wanted to know a good and educated (unlike pep boys) dealer that could do it, I've been searching but nothing good around Suffolk,VA.. just wanted to get some ideas..someone whos mostly familiar w/ camaro's would be great--cherokeegrl
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
With the car setting in place , remove the brake booster vac. line, plug off line, start car and depress brake pedal for the amount of time that it normally takes for car to die, even go a little longer. If the car stays running fine, you've found your problem (bad internal leaking brake booster). More than likely not elec. as fuses would blow if there was a dead short created when pushing on the brakes. Good luck!!
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I was tweaking around with my distributor timing this last weekend and when I advanced the timing too far, the same thing would happen: in gear with the brake on, the engine would get more & more rough until it died -- usually at ~30 seconds.
Car: 91 Camaro RS
Engine: 305 TBI
I've been monitoring my fuel economy since my distributor tweak. I went from 210 miles per tank to 250. Yay me!
I also found an exhaust leak which is freaking out my O2 sensor. I'm dumping too much fuel per cycle. Probably exacerbated my spark timing problem. Try to check for exhaust leaks upstream of the O2 sensor.
I also found an exhaust leak which is freaking out my O2 sensor. I'm dumping too much fuel per cycle. Probably exacerbated my spark timing problem. Try to check for exhaust leaks upstream of the O2 sensor. re: car turning off when brake pressed
OK, well ive been working allot lately so i havent had the chance until a week ago to have it looked at and a mechanic said it was the throttle body sensor, BUT when put in it STILL turned off! He idled my car down lower, said it was idled to high, a mechanic can't even figure out whats wrong with my car , not unless he was stupid.....this is a real pain the the ***, atleast i know its not the sensor....I'll get all of the things yal listed looked at specifically to be sure it isn't them.... Thx for all your help and if you have any more it will be very appreciated --thx---- chero
db057
Aug 11, 2015 10:11 PM
