Headlights - motor or relay?
Old Mar 1, 2006 | 11:31 AM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
I don't know which would be the problem. My lights will only pop up only after I hit the switch like 5-15 times. The motors doesn't continue to spin after there up so the gears must be fine. so can it be the relay even though they will pop up after a few tries?
Old Mar 1, 2006 | 02:26 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
could be a sticking relay or worn brushes on the motor switch. Don't rule out the gears so quick - once they engage the motor will stop when the light goes up. Have someone hit the switch while you look at the motor - if it spins when the switch is on, but does'nt move it's the gears.
The actual headlight switch could be dirty and not making good contact. Do the lamps light up when you hit the switch?
Old Mar 1, 2006 | 03:49 PM
magadith's Avatar
Engine: 305 4bbl
The lights do light up when I hit the switch.
Old Mar 1, 2006 | 03:53 PM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Then the switch is probably OK. If both headlights are doing the same thing, then it could be the master relay.http://www.autozone.com/servlet/UiBr...3d801eef19.jsp
Old Mar 1, 2006 | 05:12 PM
magadith's Avatar
Engine: 305 4bbl
Yeah, both are doing the same thing. will check out the master relay...Thanks : )
Old Mar 19, 2006 | 12:52 PM
crapper_mekanic's Avatar
Car: 1985 Trans Am/ Recaro w/webbed headrests (AS5)?
Engine: Code F
Transmission: 700, shame, ain't it?
Axle/Gears: 3.27 Borg-Warner posi
other thread
There is another thread where I wrote a paragraph on exactly how the relay headlight system works. The chillton's wiring diagram is also quite definitive on the subject when it comes to colors and function. The thread is "firebird headlights" under user "dillardracer".
Old Mar 20, 2006 | 11:17 AM
magadith's Avatar
Engine: 305 4bbl
Yup, it was the Isolation (master) relay. I went to the junk year and pulled a few of them since they were dealership parts.
Old Mar 20, 2006 | 10:20 PM
Engine: Code F
good news
Glad I could lend a hand, at the risk of egotism, saving people's asses is my claim to fame!
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
