Engine run-on with msd setup
Old Mar 19, 2006 | 04:04 PM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
I have a 92 former TBI 305 car which is now a 355 carbed. when i break the switched 12v to the msd with a toggle switch the car will shut down otherwise it runs. the msd switched 12v is ran to a IGN spade in the fuse box. distributor is msd pro-billet ran directly of the msd
tried putting a diode in the switch 12v to the msd in case i was backfeeding no luck still does it. yes i tried a different power source still does it (btw i checked it all with a voltmeter it didnt appear to be backfeeding). When i turn the key off even remove it, the alternator is no longer excited and does not charge and the fuel pump, fan, and gauges stop and it will run until it empties the fuel bowls on the carb
another thing i noticed it the SES stays on also until i flip the toggle switch off
could this be a problem with VATS??? help please TIA
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
