speed sensor not properly working
Old Mar 25, 2006 | 11:33 AM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
i was wondering if anyone knows how to recalibrate speed sensor for different gears...i know someone with expensive snap on scanner but not sure how to go about doin it
thanks
Old Mar 29, 2006 | 01:22 AM
Firebat's Avatar
Thirdgens had speedo gears that you also swap out when swapping gears. These are plastic gears that are on the vss and the taillshaft of the tranny. Not til 93 or 94 did f-bodies have the capabilities of reprogramming the ecm/pcm for correct speedo output. Ask or search around on the transmission and drivetrain forum for more info.
Old Mar 29, 2006 | 02:31 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Besides the technical article on our site, Mike Davis has a nice page on speedometer gear swaps on his website. http://www.eecis.udel.edu/~davis/z28...p/misc/speedo/.
This technical article, Changing speedo gears (4L60/700-R4), may also help you.
The gear part numbers are located in the FAQ, https://www.thirdgen.org/newdesign/f...n.shtml#tranny.
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
