Cold start problem/surging idle
Old Mar 31, 2006 | 03:25 PM
marti175's Avatar
Car: 1988 Firebird
Engine: 5.7 TPI
Facts: 1988 Firebird: 5.7 TPI: Cold start problem.
Help!
<O
Problem: When the vehicle is cold, the car cannot maintain an idle unless I hold the rpms around 1.5 or 2 until the car heats up. Then the idle maintains itself. The idle does hunt and surge sometimes between 500 and 1000 rpms. The car will start up nice and maintain an idle only while the engine is hot! Otherwise, the same game of warming the vehicle up again occurs.
<O
When I unplug the MAF sensor the Firebird starts up great when it is cold. When the vehicle gets hot, the engine does not want to produce power, so I plug the MAF sensor back in and the car runs great.
I have pulled codes and it gave me a low tps voltage code. I checked the wiring harness and it is good.
<O
Replaced: spark plugs, wires, cleaned distributor, submergible fuel pump, fuel filter, TPS (reset to .56V closed throttle), idle air control (cleaned passageways), both temperature sensors (one for the gauge), EGR valve, EGR solenoid, EGR temp. sensor.
<O
I am suspecting a bad MAF sensor. Can anyone confirm this or give me some direction? Could it be a faulty cold start switch used for the brief 8 second operation which operates only during starting? Thanks.
Old Mar 31, 2006 | 03:52 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Unless it is below 40 degrees, that cold start injector shouldnt even be operating. IS the check engine light still on once you reset your TPS?
Old Apr 1, 2006 | 11:22 AM
marti175's Avatar
Car: 1988 Firebird
Engine: 5.7 TPI
Yes, the check engine light still comes on.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
