Various wires/plugs, can these be removed?
Old Apr 6, 2006 | 06:49 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
ITEM 1 This wire goes through the firewall and connects to this relay/device thingy shown in the picture. What does this do? Can it be removed?
ITEM 2, 3 and 4....There are all plugs that come out of the thick wire loom on the passenger side of the firewall...these plugs do absolutely nothing...can i cut the ends off and cap them with a wire nut?
ITEM 5 What does this do?...can it be safely removed?...can i remove the tubes and plug the ends?
ITEM 6 These 3 (yellow, blue and orage) wires appear to be the power supply for the heater box....does that seem right?...if not, what wires shown in the picture would supply power to the heater box?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Apr 9, 2006 | 05:41 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Item 3 is for the map sensor and needed if you are still using the ecm.
Don't use wire nuts, they're tacky!!
Old Apr 10, 2006 | 01:40 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Yes, thats right...I just realized that...thanks...but what about the other plugs...what else can i use besides wire nuts?...I really don't think the plug ends look good just haning there, especially sice they have no function...
Old Apr 10, 2006 | 01:48 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Basically everything coming from the passenger side harness is items used by the puter. Most everything from the drivers sides are essentials, gauge wiring, main power, lights, wipers, etc.
Old Apr 10, 2006 | 06:48 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
PASS THE NUTS
Originally Posted by Crusin' 1980's
............what else can i use besides wire nuts?............
<CENTER><B>
When I have unused wires that I might use in the future I install them in
a connector. I then mount the receptacle on the firewall and plug it in.
This way I keep things neat in the engine compartment. </FONT>
</B><FONT COLOR=F3399><H5>
“If people drove any slower they’d be going backwards.”</FONT>
<FONT COLOR=FF66FF></H5><H3>NINÅ</H3></FONT>
<P>
<TABLE BORDER=9 CELLPADDING=8>
<TD BGCOLOR=black>
<B><H3><CENTER>REFUSE
TO
LOSE<p></TABLE></CENTER>
Old Apr 13, 2006 | 10:20 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
2 and 5 are for emmisions. 6 looks like they were for the heater controls. If I'm not using a wire, ill cut it and put a piece of heatshrink over the end of it. But usally, i'll just remove the wire from its source.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
