Do I HAVE to have a ground cable from Battery to Engine??
Old Apr 16, 2006 | 01:50 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i relocated my battery to the truck and when i did i ran my power to a cutoff switch (along with the ECM power wire/alt lead) then to a distro block in the bay.
i ran a ground cable from the battery to the frame and up front in the bay i have a huge ground strap from the pass head to the frame.
is this okay or is it REQUIRED to have a ground cable directlly from the battery to the engine???
Old Apr 16, 2006 | 07:50 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you will be good with the battery grounded to the frame
Old Apr 16, 2006 | 12:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i run mine from the drivers side head to the drivers side motor mount and it works well setup like that.
Old Apr 16, 2006 | 08:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
so a cable directly from battery top motor isnt needed? that would be nice because 1/0 welding cable is expensive!!
i was just worried because i know the factory uses one and also has a ground strap to the firewall. ive also heard something about "the big three" which i thought was a ground from batt to frame, batt to motor, and motor to frame....
Old Apr 16, 2006 | 09:32 PM
xpndbl3's Avatar
Car: 1984 Z28
trust me mine is wired up that way. ground from engine to kmember, ground from firewall to pass head in rear, and 1/0 cable from battery in back to the spare tire well, drilled a hole and inserted a 3/8" bolt and aviation nut, no issues yet at all.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
