AC Delete, Heater box wiring??
Old Apr 19, 2006 | 09:07 PM
km7152's Avatar
Car: 1991 Camaro Rs
Just finished getting rid of all my ac stuff, got the stock ac-delete box in. Went to go plug everything in and none of the connectors match up. I'm getting the connectors off the car I got the box from, but is it as easy as cutting off the old connectors, matching up wire color and splicing in?? Or I do i have to run my own wires from another source.
Old Apr 19, 2006 | 09:31 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Easiest way is to convert your AC resister over and cut as little as possible.
https://www.thirdgen.org/forums/elec...e-wire-my.html
Old Apr 19, 2006 | 09:48 PM
km7152's Avatar
Car: 1991 Camaro Rs
haha, sweet.
i love asking questions after searching hours for the answer, then getting a wonderful link that explains everything. Now if only i could find the answer by searching in the first place...maybe ill work on that
thanks, thats exactly what i needed
Old Apr 20, 2006 | 06:03 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
PICTURES
I recently had a very similar post to this regarding hooking up my Non-AC heater box...I still can't figure out how to do it!, LOL...does anyone have any pictures(up close), simply showing which wires need to be hooked up?...I'm sure thats all i would need to get mine working, pictures are very helpful to me, Thanks! The first picture shows three different color wires, which I'm guessing need to be soldered to the other (3) wires on the heater box...but I'm wonder what do i need to do with the stuff shown in the second picture.
Old Apr 20, 2006 | 09:01 PM
Engine: 383 SBC
Did you look at the links I supplied? I have directions for converting your AC wiring or doing your 1LE ones.
"The resistor that came supplied with my 1LE box had the following wiring:
Blue to side prong (Labeled #2 on my part)
2 Oranges to the top (Labeled #3, the one the closest to the PN)
Yellow to the lower prong (Labeled #1)
The orange color is the power wire. You'll want to take the 2nd orange wire coming off the resistor and hook it up to the blower motor.
My black wire doesn't even connect through the main harness. It's just a simple Chassis to blower motor face. It's the ground wire. I'm assuming if you connect up the yellow, orange, and blue to your cut harness and run the ground wire it'll work."
If you want to peel off that wiring loom I'll try to help with a new pic.
Old Apr 20, 2006 | 11:21 PM
km7152's Avatar
Car: 1991 Camaro Rs
i think have it understood pretty well. Im still waiting to get the wiring that went to the non-ac box originally, then ill sort out the mess from there. Functional or not, it still cleaned up the engine bay nicely!
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
BikeFarm
Aug 11, 2015 11:35 PM
