New VSS and VSS Buffer and speedometer still doesn't work
Old Apr 20, 2006 | 07:02 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
Ok, I put a new speed sensor and speed sensor buffer box in and my speedometer still doesn't work. Whats next? I did an engine swap to a non computerized carb and now the speedometer never moves the odometer doesn't work either. Was there something I needed to do to the ecm or cruise wires when I took out the ecm? (87 Trans Am)
Old Apr 21, 2006 | 06:58 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
anybody??
Today I dropped another 60.00 for a gauge cluster and the speedometer STILL won't move!!! This is driving me crazy!!!! Are there any tests I can do? Are there any ground wires I need to look for? Any relays in the engine compartment that I may have disconnected? The car is equipped with cruise if that helps.
Old Apr 24, 2006 | 04:25 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
never mind now I fixed it
Old Apr 28, 2006 | 12:48 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Could you enlighten the rest of us as to how you fixed it as I am having the same problem with my VSS/Speedo also.
Old Apr 28, 2006 | 04:32 PM
vwaltdog's Avatar
Car: 87 Trans Am
Engine: now a 350
What I did was to check the black with white stripe wire that is plugged into the VSS buffer box to see if it was grounded. Finding that it was not I spliced in a ground wire to it and now I have a working speedometer.
Old Apr 2, 2013 | 02:05 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
Re: New VSS and VSS Buffer and speedometer still doesn't work
wonder if this would work with the digital dash setups. where is the box located??
Old Apr 2, 2013 | 05:43 PM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
ok are you talking about the white and black wires that come strait out of the vss and if you are what exactly did you do just cut the wire down near the vss and put it on the underbody or what ':/
Old Apr 2, 2013 | 05:47 PM
Engine: 5.0
there is purple and yellow wires come out of VSS. there is a black wire with a white stripe coming from the buffer box is what i think he is talking about
Old Apr 7, 2013 | 03:29 AM
pure1959's Avatar
I just got an 89 iroc z with the l03 and t5 trans, i need help! My speedometer does not work either.
What are the most common issues and explanations for this fault please?
Old Apr 7, 2013 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You would have a mechancal speedo. Check the following link for common problems/fixes:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Apr 7, 2013 | 11:49 AM
pure1959's Avatar
Are you sure? I was under the impression that it would be an ecu controlled unit, i dont know that it is tho as i have only had the car a few hours.
Old Apr 7, 2013 | 11:56 AM
JamesC's Avatar
Are you sure?
If it's an 89 Camaro with an OE cluster, yes, I'm sure.
JamesC
Old Apr 7, 2013 | 01:09 PM
pure1959's Avatar
Great! I was hoping it would be a cable, makes life a lot easier
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
ChevyZ71
Aug 13, 2015 07:30 AM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
