Tachometer issues
Old Apr 26, 2006 | 08:30 PM
HotRodLarry's Avatar
Car: '83 Z28
Tachometer issues
I recently noticed that on my '83 Z28, the tach only reads up to about 3,000 rpms. Any idea what could cause this? The only mods I have are...MSD cap, rotor, coil, 8.5mm Super Conductor wires, K+N Filter, and my new Flowmaster cat back exhaust.I rev the engine up and the tach needle doesn't move as fast as it should. What do you guys think?
Old Apr 26, 2006 | 09:49 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Are you using the stock tach or aftermarket.
Old Apr 27, 2006 | 09:41 AM
Car: '83 Z28
Stock tach. I noticed it after I put my exhaust on. We revved the engine to hear what the car sounded like, now the tach is jumpy.
Old Apr 27, 2006 | 11:16 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Bad ground, loose wire, or wire brunt/hitting/pinched in the exhaust swap would be my first guess. Check grounds at the back of the heads, check for pinched wires, double check that nothing is hitting the exhaust.
Old Apr 27, 2006 | 09:12 PM
could be a damaged wire, or loose ground, but it could also that the tach is bad. my 89 rs had the oppsite problem it read too high.
Old Apr 27, 2006 | 09:21 PM
Car: '83 Z28
I'm going to check all the wires. I think the problem may lie somewhere near the cap and the coil.
Old Apr 27, 2006 | 11:36 PM
net_coma's Avatar
NEEDAZ is probably right. When something screws up after doing maintenance or a mod, go back to the last thing you worked on as the problem is most likely related.
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
