Wiring alternator
Old Apr 26, 2006 | 10:45 PM
ReidK's Avatar
Car: 1988 Firebird Formula t-tops
Engine: 350 60 over...400 HP
Transmission: 700 r4 transgo shift kit
Axle/Gears: stock...373?
Wiring alternator
I just did an engine swap and the alternator on my new engine is a 2 prong plug in but the wiring for the original alternator is a 3 prong plug. How do I wire my 2 prong alternator with the 3 prong wiring? Thanks
-Reid
Old Apr 27, 2006 | 02:52 PM
ReidK's Avatar
Nobody?
Old Apr 29, 2006 | 11:51 AM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
3 prong alt. plug to two prong plug.
sup man , i have an 88 camaro which had a serp. setup and i recently swapped to an 84 350 which has v-belt.
I took the biggest red wire with the single connector on it and put it on the back of the alternator where the stud is, and i took the next to largest red wire on the 2 prong plug where the red wire is there and didnt hook anything else up. It works just fine and im pulling atleast 14 volts at all times and havent had a problem. P.S. this is my first reply so please dont down me. I hope i was some help later man!
Old Apr 29, 2006 | 12:31 PM
ReidK's Avatar
thanks...I'll try that.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
