Check Engine Light after 25 minutes of highway driving...
Old Apr 27, 2006 | 01:43 AM
Waramp's Avatar
For future reference: Do you guys call it the Check Engine or Service Engine Soon light?
So my dads 90 suburban 350 TBI and my 87 350 TPI Both have the exact same problem. Drive fine around town, but after 30 minutes on the highway the light comes on out of nowhere.
Temp is fine. Dont have an oil pressure gauge. Is there a dummy light for low oil pressure?
Is there a way to check engine codes on these cars without a code reader? On my 87 Jimmy we used paperclips for jumpers and watched the light blink...
If theres a FAQ on all this stuff please someone forward it to me. thanks!
Old Apr 27, 2006 | 09:30 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
THE CONNECTOR
| 1 2 3 -4 -5 -6 |
| 7 8 9 10 11 12 |
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective.
Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12. No reference pulses to Electronic Control Module (ECM).
13. Oxygen sensor signal stays lean during warm engine cruise
14. High temperature indicated at engine coolant temp. sensor
15. Low temperature indicated at engine coolant temp. sensor
16. High battery voltage OR
Direct inition system open or shorted to ground
17. RPM signal problem
18-20. N/A
21. High voltage at throttle positon sensor
22. Low voltage at throttle positon sensor OR
Fuel cutoff relay circuit open or shorted to ground
23. Low temperature at manifold air temperature sensor OR
Throttle position sensor error
24. Circuit fault in vehicle speed sensor
25. High temperature at manifold air temperature sensor OR
Vacuum switching valve circuit open or shorted to ground OR
High voltage at ATS sensor
26. Fault in quad driver module
27. Fault in 2nd gear switch
28. Fault in 3rd gear switch
29. Fault in 4th gear switch
30. N/A
31. Low voltage at manifold absolute pressure sensor OR
Fuel injector OR
Park or neutral switch OR
CAM diagnostic OR
Governor malfunction OR
Wastegate overboost OR
Wastegate eletrical signal open or shorted to ground
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35. Idle speed can not be set to desired RPM
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
37. N/A
38. Fault in torque converter clutch brake switch
39. Fault in torque converter clutch circuit
40. N/A
41. Fault at cam sensor OR
Cylinder select error OR
Tach input error
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
43. Low voltage at electronic spark timing circuit
44. Oxygen sensor lean
45. Oxygen sensor rich
46. Fault at vehicle anti-theft sytem OR
Fault at power steering switch
47. Problem at Electronic Control Module (ECM)
48. Misfire
49. Vacuum leak
50. N/A
51. PROM error
52. Problem at Electronic Control Module (ECM) -
Missing fuel calpac missing OR
Analog to digital converter error OR
Fault at quad driver module OR
Low voltage at oil temperature sensor
53. High voltage at battery OR
High voltage at exhaust gas recirculation valve OR
Voltage reference error OR
Problem at vehicle anti-theft system
54. Low voltage at fuel pump OR
Low voltage at Fuel pump relay OR
Output failure at quad driver module
55. Problem at Electronic Control Module (ECM) -
ECM failure OR
Serial bus error OR
Fuel lean malfunction
56. Low coolant or corrosivity OR
Fault in port throttle system vacuum sensor
57. N/A
58. Problem at vehicle anti-theft system
59-60. N/A
61. Oxygen sensor degraded OR
Port throttle system error OR
Cruise control problems
62. Gear switch input diagnostics OR
High voltage at oil temperature sensor OR
Fault in cruise control- vacuum solenoid circuit
63. High voltage at manifold absolute pressure sensor OR
Fault in exhaust gas recirculation valve OR
Fault at right oxygen sensor
64. Low voltage at manifold absolute pressure sensor OR
Right oxygen sensor lean
65. Failure at exhaust gas recirculation valve OR
Faulure at injector peak/hold diagnostic OR
Right oxygen sensor rich OR
Fault at cruise control position sensor
66. Internal reset of Electronic Control Module (ECM)
67. Fault at cruise control switch
68. Fault at cruise control switch
69. Fault at air conditioner pressure switch
70-87. N/A
88. Internal reset of Electronic Control Module (ECM)
__________________
Old Apr 27, 2006 | 11:08 AM
Waramp's Avatar
Thank you very much!
Old Apr 30, 2006 | 11:19 AM
91black5spd's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 5 speed Manual
I have the same problem. Did you find out what the problem is???
Also, where is the connector panel? In my shop manual it says under the dash on the drivers side but I dont see a panel there. My car is a '91 so maybe they changed it but I can't seem to find it.
Old Apr 30, 2006 | 02:12 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Next to the fuse block
EDIT: The door is in the drivers plastic kick panel on the left. It should say fuse panel or something like that.
Old May 1, 2006 | 07:00 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
location
Attached Thumbnails Check Engine Light after 25 minutes of highway driving...-aldlplug.jpg
Old May 1, 2006 | 10:36 PM
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
I guess firebirds are different from camaros
Old May 2, 2006 | 07:14 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
nope, connector is at the same place for all thirdgens.
Old May 2, 2006 | 10:19 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
it's probably the EGR most likely
Old May 15, 2006 | 10:38 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
My car dose the same thing. Hooked a scaner up to it and pulled the code for the egr. Adam :-)
Old May 15, 2006 | 11:23 PM
Engine: 305 TBI
I ended up changing the O2 sensor and it hasnt thrown a code since so hopefully thats all it was. If it does it again Ill scan it.
Old May 17, 2006 | 01:10 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Just as an FYI the Newer 90-92 ADL connector is is not in the same place as the older 3rd gens it is more towards the middle by the column
Old May 17, 2006 | 12:06 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Sounds like O2 or EGR.
Old May 17, 2006 | 02:37 PM
Engine: 305 TBI
Yeah mine ended up being on the left side just behind the fuses. I couldn't find it before because the old owner had wire tied the fuse box cover over it because the cover had cracked.
Old May 17, 2006 | 07:03 PM
Raiderfan's Avatar
Car: '92
Old Jun 4, 2006 | 10:14 PM
Waramp's Avatar
changed out the O2 sensor. Now its giving me codes 21 and 32. TPS and EGR. Im going to go and take a look at the plug/wiring on the TPS. Where do i start with the EGR valve? thanks
Old Jun 5, 2006 | 12:12 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
make sure that the egr valve is not physically frozen.
Follow this link, it should se you in the right direction.
https://www.thirdgen.org/egrdiagnose
-Brendan
Old Jun 14, 2006 | 01:51 AM
Waramp's Avatar
Where exactly is the EGR valve located on an 88 TPI car?
Is there a few different types of EGR valves?
Im guessing its black plastic, bolted onto the intake with a vac line coming off of it?
Will i have to take the plenum off to get at/inspect it? thanks again!
Old Jun 14, 2006 | 10:06 PM
Toehead's Avatar
87-89 350 TPI 85-86 305 TPI EGR Valve
That is a picture of your EGR valve. To test if it is physically functional, let the engine warm up and idle. The silver part with the little vac line will be on top. Reach up under the silver part, there will be a diaphram you can push up on. The diaphram should move and the engine should almost stall.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
