Got Towed Home:gocrazy:
Old Apr 28, 2006 | 01:30 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
I was driving to the body shop and all the sudden my car just dies. i used all my muscle to steer it out of the street....I what would make my car just die while driving????
Old Apr 28, 2006 | 07:09 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
need more info, does it crank, if yes first check for spark if there is no spark disconnect the tach lead a shorted tach lead could cause it to loose spark, test battery, test charging system if the battery is dead. More info will be needed to help diagnose.
Old Apr 28, 2006 | 09:03 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
no battery isnt dead. it just didnt start. The main thing is my car died on me while driving. No it didnt crank
Old Apr 29, 2006 | 01:46 AM
rezinn's Avatar
Test for fuel and spark then come back.
Old Apr 29, 2006 | 01:21 PM
Jza's Avatar
Jza
Typically the fuel pump. Test the fuel pressure.
Old May 3, 2006 | 02:25 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If "No it didn't crank" means the starter is not turning the engine at all,
probably means a major power distribution failure. Does anything else (lights, accessories, etc.) work. If not, look for failed connections/broken wires in the 10 gauge wires that connect to the positive battery terminal, and supply all the other systems. On my 90 Formula, there are several that are connected at the main connection on the starter. Best case, that nut has come loose.
Otherwise: on this same Formula, a sensor module in the distributor failed. Most good autoparts stores can test these modules. A GM dealer charged me $240 for this lesson.
It may sound trivial, but it bit me in the *** on more than one occasion. Start at the battery, & look for corroded, loose, or broken connections.
Good luck,
kk
Old May 3, 2006 | 06:09 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
yes all my electronics example system lights windows all work. It just didnt start do to i think my hot start issue which im fixing today
S10K20
Oct 7, 2015 06:45 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
thekurlyone
Sep 30, 2015 12:54 PM
dimented24x7
Sep 17, 2015 06:58 AM
TBRays98
Sep 6, 2015 05:05 PM
