Fuel Gauge problem
Old Apr 30, 2006 | 07:00 AM
fessor's Avatar
Fuel Gauge problem
86 IROC, all gauges work accept the fuel gauge. It reads over full all the time. Any suggestion what to do?
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Apr 30, 2006 | 12:02 PM
Firebat's Avatar
its probably a bad sending unit. And the sending unit is in the gas tank which means dropping the rear axle and dropping the tank.
You could test it with an ohmmeter/multimeter by finding the pink wire that goes to the fuel tank and measuring that wire and its resistance to ground. Connect black test lead of meter to the metal chassis and the red test lead to where you want to test for resistance. The third gen sending unit reads 90 to 0 ohms depending on how full the tank is. A full tank reads 90 ohms. If its reading 90 ohms and you're tank is not full then its your sending unit. If you take your gauges you will see two connectors. For 86 camaro, Connector C1, pin 4 connects to the wire that goes to the sending unit.
If it doesn't read about 90 ohms and you have nothing even close to a full tank then the gauge itself is probably bad.
Old Apr 30, 2006 | 01:27 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
accept ??
except..
may also be caused by loose or dirty connection at the instrument panel plug pins,
happens on the s series trucks all the time like in my 91 and my brothers 92
causes all kinds of problems with guages
good luck
Old May 5, 2006 | 06:20 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Yeah, my fuel gauge is slow to read it's level. It works, but it's really slow. Say I'm empty then fill up, I turn the car on after it's full and the needle takes like 2 minutes to go to full. Why does it do that?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
