Starter Selenoid wiring help
Subscribe
May 3, 2006 | 07:58 PM
Im doing the gold old hot start cure fix. However I got the power wires hooked. But im having trouble with the ignition & etc wires. There all orange and have no clue how to hook them up. PLease Help ME
Reply 0
May 3, 2006 | 08:53 PM
Do you have a pic of the wires that you don't know what to do with?
Reply 0
May 3, 2006 | 09:25 PM
i think the ignition switch and ignition safety switch crimped together. that leaves the igntion coil wire left..
Reply 0
May 3, 2006 | 09:33 PM
Here's the pic from the tech section. The only thing is my starter selenoid that is on the starter has two post. But all wires were hooked to one. I also had a negative wire hooked to the selenoid from the starter. Do i still need that shortout plate??? PLease im going to finish this tomorrow.
Reply 0
May 3, 2006 | 10:13 PM
You should have a large cable from the battery going to the post marked "B" along with two or three smaller red wires that are fusible links. There is a post below the one marked "B" that has a lead going to the starter itself. There is not a wire or any thing else going from that post marked "I" to the post marked "B". There is a small purple wire going from the "park/neutral" switch (automatic) or "clutch safety" switch (manual) to the post marked "I".
Reply 0
May 3, 2006 | 10:21 PM
i got three wires which are fused, there all orange. So let me get this right
1. is a black wire from selenoid to starter
2.has no wires hooked to it
3. all wires includind power wire hooked to it
Sound right
Reply 0
May 3, 2006 | 10:39 PM
please explain what you mean with the 1,2,3 you have in your post.
Reply 0
May 3, 2006 | 11:17 PM
my buddy got me straight Thanks any how
Reply 0
May 4, 2006 | 10:32 PM
SUCCESS!!!! Got it all wired and drove it and restarted everytime!!!
Reply 0
Subscribe
