98Z28 won't start
Old May 8, 2006 | 11:09 AM
89RS&98Z28's Avatar
Car: 1989RS////1998Z28
Engine: 305////350LS1
Transmission: 700R4////4L60E
98Z28 won't start
Maybe you guys can help with my newer one. No power to starter, with jumper wire car will turn over but not start. fuel pump comes on, but not sure of injector pulse or not. Will check that and fire once I get it to shop.
But this seems like anti-theft issue similar to vats. So will the resistor bypass work here?
Old May 8, 2006 | 05:52 PM
89RS&98Z28's Avatar
Well, turned out to be vats,resistor cured problem. Just shows that gm is still using same pos ignition switch in tilt colums. Almost always a broken wire.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
