Another Sequential Turn Signal Post
Old May 14, 2006 | 12:15 PM
WinnipegGTA's Avatar
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Hey all i just bought the Web-electric Sequential kit. However in looking at the lights on my '91 GTA without taking the actual lense off it appears there are 3 bulbs in there on each side the 2 inside one are for the brakes and running lights and the outside yellow one is a single filament turn signal one. I know a couple of you out there have posted in a previous post about this and i didnt' want to dig up a grave. I just want to know if this is how all firebirds are setup of if the 91-92 GTA had a special setup all to them selves cause the description ive been reading about the older pre 91 cars sound like they are are wired different. Please help! thanks
Old Sep 9, 2006 | 01:34 AM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Going to try to undertake this tomorrow. Anyone know if the tail/brake light wiring was revised for 91-92 in GTA's
Old Sep 9, 2006 | 08:57 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I don't have an answer for your question (sorry!), but I'm hoping that you can post the information about the company that you bought the kit from. This is something that I've always had in the back of my mind to do to my GTA...
Old Sep 9, 2006 | 04:34 PM
Car: 1991 GTA
Engine: 5.7L L98
Transmission: 4L60
Sure can.
WebElectric Products - 2005 2006 Sequential Turn Signals, Taillights, Tail Lights, Pulsing Brake Light Pulser Flasher, 2005 2006 Mustang Grille, Dynamite Stick, Pony Package, Daytime Running Lights, Light Bar Switch, Styling Bar Switch, Dome Light Dimmer (Theatre Lighting), Mustang Corral, Mustang, Corvette, Impala, Fiero, Trans Am
Old Sep 10, 2006 | 12:00 AM
V8Rumble's Avatar
Sweet, thank you sir!
Old Oct 22, 2006 | 11:27 PM
Stephen's Avatar
Car: 87 GTA
The outer most bulbs are single filament tail lights, the inner two are dual filiment, tail/turn signals. However, the tail light housings are the same. So, get a spare harness, cut the sockets off the inner two, and use them for your cars harness, so that the 3rd buld will work as tail/turn
Then, you can use all 3 bulbs, as sequential turn signals, without the 3rd bulb not doing anything.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
