Gauge Cluster Harness Adapter (Where do I get one?)
Old May 17, 2006 | 12:11 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I've got some autometer gauges and a plate I built for them. I was wondering if anyone knows where or if it exists, to get a female connector to connect to the factory harness? There isn't alot of wire to cut the original connector off so I thought I'd ask before I went that route.
-Paul
Old May 17, 2006 | 03:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check Chevy High Performance, June issue, I think. Autometer gauges were swapped into an 84 Camaro. IIRC, the article stated that since there was currently no connector available, the wiring had to be repinned--or something to that effect.
JamesC
Old May 18, 2006 | 12:17 AM
Can't seem to find it. 2005 June?
Old May 18, 2006 | 03:34 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You have to cut the wires and use the supplied connectors, if you are using the autometer dash kit from Covan's. If you aren't, then you just need to splice them accordingly so you will be able to disconnect the gauges if you need to.
Old May 18, 2006 | 05:25 AM
JamesC's Avatar
May or June, I think, 2006.
JamesC
Old May 18, 2006 | 12:08 PM
It's my own kit.
I'll just splice them in I guess. Probably hit baxter's for some connector blocks rather than a bunch of those male/female connectors.
64goatman
Sep 9, 2015 01:09 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
