==HELP! Interior Lights Dont Work! HELP!==
Old May 19, 2006 | 12:43 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright, when Autozone put in my battery after being recharged, my little lights around the SYSTEM CHECK Screen that say, RES, TRIP, AVG, and what not, they dont light up anymore,
The lights on my AC/HEAT control, the ones that say, HEAT, MAX, NORMAL, VENT, they dont light up anymore either.
FINALLY, the lights on my shifter, P,R,N,D,2,1, they no longer light up.
What is causing these lights not to light up anymore?
Old May 21, 2006 | 01:49 PM
Firebat's Avatar
Have you checked your fuses to see if one is blown?
Old May 21, 2006 | 08:24 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
yeah, ive replaced the ACC, GUAGE, and CLSTR fuses, no different
Old May 21, 2006 | 08:57 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Have you thought that maybe the light bulbs are dead?
If everything else is working, except for a few select lights, it's probably the bulb.
Old May 21, 2006 | 09:01 PM
Beachmonkey6's Avatar
Car: '88 GTA
Engine: L98 -350TPI
Ive got the exact same problem that you have. Same lights and all dont work. Except my rear driving lights also dont work. About 10% of the time the lights come on for some reason. But i have noticed that the rear driving lights do work when the shifter P,R,N,D,2,1 work, but only then. Also my brake lights do always still work. Id really like to figure out what the problem is! -Austin
Old May 21, 2006 | 09:33 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
ok, so how do I take the center console piece that my shifter lights are on to replace them? and how about the lights by my SYSTEM CHECK screen?
Old May 21, 2006 | 10:43 PM
Car: '88 GTA
Engine: L98 -350TPI
you know what... i just figured out what the the problem was in my t/a. The black button that you push to turn on the driving lights and half the interior lights(the ones that arent coming on for you) is finicky. When i push it in, the lights dont come on. I have to push extra hard and sometimes wiggle it to get them to come on. You might check there because it sounds like we were dealing with the same lights. But goodluck. -Austin
Old May 22, 2006 | 12:44 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
well, it wasnt the switch, i dont know what it could be, im just gonna replace the bulbs and see if that works.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
