Electronic problem after conversion
Old May 20, 2006 | 07:24 PM
inisross's Avatar
Help.....Jim, Tim, & Trickster or Anyone with ideas!
My husband is trying to iron out one last problem with an 700R4 to T5 conversion. This has been one headache after another, a very long process.
Our Car is: 1988 V6 Camaro RS (yes, the one they only sold in CA, TX & FL) No cruise standard speedometer (not digital)
Hydraulic clutch is from a 1987 Camaro V6
Transmission is from a 1989 Camaro V6
We replaced the auto prom with a manual prom.
Problem:
The car intermittently idles high 1500-2000, and the service engine light goes on and off. It registers an error code 24, is this probably a VSS error? The high idle will sometimes kick down right after starting and/or driving, and sometimes takes a long time, and sometimes not at all during that driving sequence. The same with the service engine light. How do you check the circuit for the VSS?
Old May 21, 2006 | 09:51 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
I'm not sure how to check the VSS, but i would seriously concider the idea that the chip you tossed in is fubar'd, or something totaly unrelated (tps sensor?). Keep us updated though! and good luck!
Old May 22, 2006 | 09:55 PM
Zrunner90's Avatar
Car: 1990 Camaro RS Ttops
Engine: 89 IROC 305 TPI
Transmission: M5
Axle/Gears: 3.23 limited slip
could be the tps? My car used to do something similar to that, it would idle up real high (2000+ rpm) the drop and almost die...if you have fuel injection....check the injector wiring also.
Hope that helps
Eric2ndGen
Nov 5, 2015 01:51 PM
86CamaroDan
Sep 29, 2015 10:08 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
