A/c kicking on with heater
Old May 22, 2006 | 03:52 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I've noticed that when I turn on my heater and I'm at an idle my a/c compressor comes on and goes off every few seconds.It makes my idle fluctuate a couple hundered rpm when it does it and it's annoying.Anybody have this happen?
Old May 22, 2006 | 04:28 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
same here... and when the a/c is on it doesnt blow cold but I can feel the lines are cold
Old May 22, 2006 | 04:34 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Mine blows cold when I have the controls on cold but if I want the heater on then the compressor just comes on and goes off in about 5 sec cycles.
Old May 22, 2006 | 04:52 PM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
also someone mounted the switch to the electric fan to the a/c so when i have it on the a/c goes on wasting my gas.. I'm thinking they messed up the wiring??
Old May 22, 2006 | 06:54 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Just to clarify... this is when your controls are set to vent, defrost or heater? Because if you have the A/C selected (Max, Norm, Bi-Lev) and you flip the temp to hot, the compressor will still come on.
Can you explain that please? Are you saying that someone wired in a switch so that when you turn on your blower motor, it turns on the A/C?
Old May 22, 2006 | 07:00 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Yep,I can have the controls on defrost/hot and it blows hot but the compressor still kicks on.If I have the a/c on it stays on.
Old May 22, 2006 | 07:34 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
all cars do that
Old May 22, 2006 | 08:08 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
All cars a/c compressors run when the heater is on?None of my other cars do.
Old May 22, 2006 | 08:10 PM
super_kev's Avatar
Car: '85 TA
I agree, mine don't either. You might want to check your HVAC controls, as some wires might have been worn down and things might be crossing over. That's all I can think of at the moment...
Old May 22, 2006 | 08:35 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
like Jproz1167 said ALLcars do it. If you have your defrost on your a/c compressor will kick on and than turn back off. Every single vehicle out there does it if you notice or not, even all the new cars. Most people dont realize it or able to tell depending on the cars it is easier to hear the a/c compressor kick on.
Old May 22, 2006 | 08:45 PM
super_kev's Avatar
Car: '85 TA
Yes, it comes on with defrost selected. But with the vent and heater, it does not.
Old May 22, 2006 | 08:57 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
than it is working as designed
Old May 22, 2006 | 10:43 PM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
It does it on every setting.
Old May 22, 2006 | 10:50 PM
super_kev's Avatar
Car: '85 TA
fbird92... 87tpi has the problem, not me. His A/C comes on with the vent and heater settings. I would suggest finding another HVAC control unit from the junkyard and see if that solves your problem. I'm looking at the wiring diagram and nothing looks like it would cause that to happen, so maybe your control panel went south.
Old May 22, 2006 | 11:45 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I agree with Super_kev you may have a bad HVAC head unit.But as others have stated the compressor does come on when you select defrost.This is done to control humidty.The compressor short cycling,cutting in and out very often,could be a sign the system is low on refrigerant.
Old May 23, 2006 | 05:54 AM
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
What I mean is the car has a manually controlled electric fan wired to the A/C, so when it starts running hot you have to put the A/C on, which is pretty much a waste of gas/power
Old May 23, 2006 | 03:17 PM
super_kev's Avatar
Car: '85 TA
Your fan temperature switch is probably wasted and needs to be replaced.
mcfastestZ28
Oct 1, 2015 11:23 AM
tattmann
Sep 27, 2015 05:20 PM
