Ignition timing problem
Old May 26, 2006 | 02:28 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
I can't time my sons 86 firebird 305 "H" code. To get it to run I have to time it with the distributor plugged in. Timing it unplugged and then plugging it in does not advance the timing, we have tried everything. 3 ign. modules, coil, pickup coil, wires, plugs even the computer. We found the cat had taken a crap and clogged the exhaust, replaced it but it barely helped. The car is driveable but timing is off about 70 deg. and little power. Someone told me that the distributors had 6,7 and 8 gears on them and I have the wrong one. It makes sense but I can't find any info, He ttook it to 2 shops and they could not find the problem. SOMEONE PLEASE help !!!! It has a hei distributor no vac. adv. 7 pin module
Old May 26, 2006 | 03:00 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
are you getting the check engine light on?
if you are check to see if your getting a code called " 1x referance "
Old May 26, 2006 | 03:11 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
I am what does it mean
Old May 26, 2006 | 03:13 AM
Car: 1985 TransAm
Engine: 5.0L TPI
it means that the ECM is not receving Feedback from the distributer
Old May 26, 2006 | 03:15 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
Any idea what to check for
Old May 26, 2006 | 03:19 AM
Car: 1985 TransAm
Engine: 5.0L TPI
ignition module , ecm connector , ignition wiring
Old May 26, 2006 | 03:20 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
put 3 modules in it and a ecm
Old May 26, 2006 | 03:22 AM
Car: 1985 TransAm
Engine: 5.0L TPI
sounds like a wiring issue.... if computer isnt recieving information from the distributer thats what 1x referance means a feedback failure
Old May 26, 2006 | 03:25 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
2 shops had it for a week a piece and could not tell me that. 1 mechanic told me to ignore that one.
Old May 26, 2006 | 03:26 AM
Car: 1985 TransAm
Engine: 5.0L TPI
there should be 4 wires hooked into the Dist / Ecm communications
1. black/red
2. purple/white
3. white
4. tan/black
then there should be 2 other wires as well
but have no ecm communication to the ecm
1.pink goes to ignition switch
2.white goes to inst. cluster
Old May 26, 2006 | 03:28 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
any idea how to check them ? Thanks for your help
Old May 26, 2006 | 03:36 AM
Car: 1985 TransAm
Engine: 5.0L TPI
well its gonna be a bitch 100%
but my only way id say is the tug 'n snug check make sure all connections ok
then check for damaged / frail wiring
here is a place for a wiring diagram
look for the 86 model year
</title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>");
newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>");
newWindow.document.writeln("<br/>");
newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright &copy; 2002 Delmar, All Rights Reserved.</font></div></body>");
newWindow.document.writeln("</html>");
newWindow.focus();
newWindow.document.close();
newWindow.print();
function pop_norm(pc, tpe, sze)
newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120");
newWindow.document.writeln("<html><head><title></title></head>");
newWindow.document.writeln("<body><div align='center'><img " + getWidth("no") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>");
newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("no") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("no") + "\");'></FORM></td>");
newWindow.focus();
function getValueToPass(valPassed)
if(valPassed == "yes")
return "no";
else
return "yes";
function choose(formAction)
with (formAction)
ref=options[selectedIndex].value;
document.location=ref;
function getButtonValue(val)
if(val == "yes")
return "Enlarge Image";
else
return "Print Image";
function getWidth(prnt)
if(prnt == "yes")
return "width='650' ";
else
if(prnt == "no")
return "";
</script>
<title>AutoZone.com | Repair Info | GM Firebird 1982-1992 Repair Guide | Chassis Electrical
</title></head>");
newWindow.focus();
newWindow.print();
newWindow.focus();
return "no";
else
return "yes";
with (formAction)
if(val == "yes")
else
if(prnt == "yes")
else
if(prnt == "no")
return "";
</script>
Last edited by FireBirdKnight; May 26, 2006 at 03:37 AM. Reason: Automerged Doublepost
Old May 26, 2006 | 03:38 AM
da birds's Avatar
Car: 86 firebird
Transmission: auto
Thanks again, if it works I really owe you. Need any parts
Car: 1985 TransAm
Engine: 5.0L TPI
or just go to the autozone website since it has a issue with TGO links
voltmeter , wiring diagram bout all i can think of
good luck ....it really sounds like the relationship between dist and ecm is bad keep us informed....
Last edited by FireBirdKnight; May 26, 2006 at 03:41 AM. Reason: Automerged Doublepost
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
