Homemade shift light
Old May 29, 2006 | 06:56 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Has anyone the electronics knowledge to create a simple shift light from scratch with leds? Just the translation between the voltage of the tach wire and rpm would be a great place to start at. Any thoughts on how to make it adjustable would be great. I know somebody graduated college in this field.
Old May 29, 2006 | 07:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There is no translation of voltage to RPM on the tach wire. The tach signal is pulsed.
Old May 30, 2006 | 07:52 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Look around for 'frequency to voltage converters'. Go from there...
Old May 31, 2006 | 12:56 PM
pizza_guy's Avatar
thank you needaz
Old May 31, 2006 | 01:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why use analog when it would be so much better to do the whole thing digitally?
Old Sep 15, 2007 | 10:17 AM
85_ZED28's Avatar
Car: '85 Z28
Re: Homemade shift light
Is the signal to the tach 1 pulse per engine revolution?
Old Sep 15, 2007 | 04:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, 1 per ignition firing. The tach lead is connected to the coil primary.
Old Sep 15, 2007 | 04:35 PM
85_ZED28's Avatar
Car: '85 Z28
ok thanks, so that would be 4 pulses per rev, correct?
Old Sep 15, 2007 | 04:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On a V8, yes.
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
