Relay ??
Old Jun 1, 2006 | 04:20 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Relay ??
Is there a relay or inline fuse that goes to the heater fan,power locks, interior lights,power mirrors and power hatch??Because none of them work,but the door locks work with the alarm switch and not the lock buttons.
Old Jun 1, 2006 | 04:42 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Check the fusable links down by the starter, it's possible one of them has burned through. I doubt its a fuse or relay as there are 3 or 4 different circuits involved.
Old Jun 1, 2006 | 05:21 PM
Z03Z28's Avatar
Where would they be located at?I'm new to electronic work.
Thanks Lanaue
Old Jun 1, 2006 | 06:05 PM
The big nut on the starter solonoid where the battery cable goes there are some other wires there, usually orange, that have fuse links in them, their black about 1-1/2" long, one of them is probably burnt out. This involves getting under the car, be sure to safely support it on jackstands or ramps
Old Jun 2, 2006 | 12:08 AM
Z03Z28's Avatar
Thanks I'll put it on ramps saturday.Will a bad link look burned?Is it easy to see?
Old Jun 2, 2006 | 12:16 AM
Z03Z28's Avatar
I really appreciate your help,I have been trying to find the problem for months
this is what this board is all about.Thank you Thank you thank you
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
