2nd accessory power
Old May 28, 2006 | 05:06 PM
Johnnywilde55's Avatar
Car: 87 Iroc, 88 Camaro
Engine: 5.7L TPI, V6
Transmission: 700r-4, t56
2nd accessory power
the car is already wired for accessory power as in when you turn your car to acc. the stero turns on ect.. well i want to run a heaveir cable into a 2nd fuse box so i can run some bigger accesories that i want to run while the car is on and in the acc. position. any ideas on how to hook it up? because i cant just run a wire from the battery because that would be constant power and i dont really want to install a switch. so where would i hook up a heavier wire so i can have it run on the acc. postion?
Old Jun 2, 2006 | 08:17 AM
Stephen's Avatar
Car: 87 GTA
I would run power to a second distribution box, through a strong relay, and power the relay off the main distribution black, using a key on position.
Azrael91966669
25
Jun 20, 2017 04:04 AM
NiG
Oct 11, 2015 08:42 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
