92 Camaro Speedometer / Odometer stopped working
Old Jun 1, 2006 | 10:55 PM
scotth3680's Avatar
I have a 92 camaro RS 8 Cylinder TBI - the speedometer stopped working one day- I was driving down the road and it froze at 33Mph - the odometer and tripometer also stopped working. When the car is powered off, the Speedometer still sits at 33 Mph - I've checked the speed sensor in the tailshaft of the transmission and it checks out okay, no trouble there. What really has me confused is the fact that the speedometer is just stuck at 33Mph. I took the instrument cluster out and the speedometer needle does move freely if you move it with your finger - What could be wrong? Speedometer cluster itself?
Old Jun 1, 2006 | 11:13 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Dunno, but I just so happen to have a 145 cluster out of my 91 Z28 for sale. Perfect working order!
Old Jun 3, 2006 | 02:42 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
If the speedo is pegged at a certain speed, but the odometer doesn't move, then the cluster is bad. Otherwise, the car would rack up milage to the tune of 33 miles every hour that the key is on. This would be the case if your VSS went bad and simply put out a steady voltage that mimicked 33 MPH.
Old Aug 25, 2009 | 12:38 AM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Re: 92 Camaro Speedometer / Odometer stopped working
I just posted in the electronics board with the same issue. Did this one ever get resolved??? How did you do it?
Frozer!!!
Jan 19, 2024 04:55 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
marcusaw
Aug 10, 2015 08:13 AM
kyle5647
Aug 7, 2015 03:08 PM
