Removing turn signals & steering column fix
Old Jun 3, 2006 | 08:28 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
I have the same loose steering column problem we all have in a 91 RS automatic 305. I have it dissassembled down to the turn signals and am very intimadated from there and have stopped. I can easily take them out but replacing could be a problem! Help! any suggestions ? I know where the inverse torx bolts are snd I'll have to pull a tilt pin to get down even further and find a pin puller to do this. Should I just pull the whole column and take it in to a shop or just replace if i can find one? Replacing would probably be easier than this fix but more expensive of course.
Attached Thumbnails Removing turn signals & steering column fix-dscn0244.jpg
Old Jun 7, 2006 | 09:42 AM
Vader's Avatar
The "pin puller tool" is nothing more than a 2" long 8-32 screw, a nut, a couple of fender washers, and a ½" socket:
And using it is rather self-explanatory once you have the pins exposed. Assemble the parts as shown, thread the screw into the tapped hole in the pivot pin, and turn the nut against the washer to remove the pin.
Don't forget to lubricate everything when you reassemble. You'll also want to make sure the pins are snug in the bores or the column will still be loose. If the holes are worn, you'll either have to replace the upper bowl section or install bushings:
Old Jun 7, 2006 | 10:40 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Thanx Vader, I got it all back together, nice and tight!
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
Fronzizzle
Aug 9, 2015 01:15 PM
