Radiator Fan Temp Guage replacement
Old Jun 3, 2006 | 06:01 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I want to replace my stock fan sensor in my 84 Trans Am (the one that tells the radiator fan to turn on and off) with one that starts at a little lower temperature. The problem is, not sure where this sensor is. Any help would be greatly appreciated. Is it coming out between the number 1 and 3 cylinders?
Old Jun 6, 2006 | 12:55 AM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
The sensor between 1 & 3 cylinder is for the temp guage. The sensor you are talking about is between cylinders 6 & 8. Their should be a green wire coming out of it. If you ground the wire while it is still connected to sensor w/ignition on the rad fan should engage.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Leggman1
Aug 6, 2015 04:15 AM
