Coil wire cut
Old Jun 5, 2006 | 07:58 AM
Time's Avatar
Coil wire cut
Ok, so I removed the pesky alarm system from my 91Z this weekend. It was cluttering my underdash.
After doing so, I found a white wire from my coil disconnected.
The coil has 2 plugs, both with a white and red (or pink) wire.
The one (on the drivers side of the coil, so to speak) is not even connected. And the car still runs. should this be and what are those wires to?
I am however, having an issue with my right turn signal indicator and high beam indicator light coming on when driving at night It comes on every so often. Usualy when I hit bumps. Plus my AMP gauge sometimes show a negative charge, But the alternator appears ok when checked the old fashioned way by removing the positive terminal to se if it dies. It does not.
Old Jun 5, 2006 | 11:12 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Does you tach work?
Old Jun 5, 2006 | 11:16 AM
Time's Avatar
Yes. all gauges work.
I guess I should say voltage gauge, not amp.
It sometimes wants to go to the discharge side. But only sometimes.
My concern is where does this wire suppose to go so I can just hook her back up.
Old Jun 5, 2006 | 03:25 PM
Wadebryant's Avatar
Will check and get back to you.
Old Jun 6, 2006 | 05:57 AM
Wadebryant's Avatar
The white wire from the coil goes to the 90-92 ecm 1227730, pin C8 for the EST signal. I checked this against a 91 that I'm working on. For more pinout and other info you can also check the Chevy Thunder site. Chevythunder
Old Jun 15, 2006 | 10:58 AM
Time's Avatar
The wire only reaches to my firewall just inside on the drivers side.
The coil, of course, has 2 sets of red and white wires. Which white one were you refering to? The one disconnected on mine is on the drivers side ,per say.
Is it possible that this may be the wire that powers my power mirrors,int lights, rear hatch release,power locks and rear view mirror lights not working? Just thought of that since I been trying to fix that issue also.
Old Jun 15, 2006 | 02:31 PM
Wadebryant's Avatar
My first thought was to ask you about the tach. Second, was the (other)white wire which runs to the ecm. Anyway, check it against the electircal info found at the chevy thunder site. It may or may not help?
Old Jun 15, 2006 | 02:45 PM
Time's Avatar
The one disconnected on mine is the smaller white wire.
Its saying on that site: "the smaller pink and white wires which goes to the 2- wire connector on the ignition module on the distribitor."
Where is that?
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Winchester1094
Aug 18, 2015 10:23 AM
midias
Aug 15, 2015 05:07 PM
TA8487
Aug 11, 2015 09:02 PM
