Fog Lamp Relay Connections 88 Camaro
Old Jun 5, 2006 | 11:20 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I have the relay, wires etc I need to install the factory setup for fog lamps in my 88 Camaro. Only problem comes down to the relay. I have 5 wires but the GM wiring diagram I have only shows 4 connections. The wiring diagram labels each connection on the relay 1, 4, 2, and 5. So according to this diagram the following terminals on the relay would correspond to the number on the female relay connection.
Relay Connection 1 = Terminal 30
Relay Connection 2 = Terminal 85
Relay Connection 3 = Terminal 87a
Relay Connection 4 = Terminal 87
Relay Connection 5 = Terminal 86
My problem is the GM wiring diagram does not show where the relay connection 3 needs to go. Is this just a useless wire? I have searched for help on this and everyone seems to wire this up their own way. I am just following the factory wiring.
I looked at this post:
https://www.thirdgen.org/forums/elec...ight=Fog+Relay
But that did not look to follow factory wiring. Any assistance is appreciated, thanks.
Attached Thumbnails Fog Lamp Relay Connections 88 Camaro-dsc00013.jpg   Fog Lamp Relay Connections 88 Camaro-dsc00014.jpg   Fog Lamp Relay Connections 88 Camaro-dsc00015.jpg
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
