Wiring for different Gauge Cluster.
Car: 1984 Camaro Sport Coupe
Engine: 2.8L V6
Hey guy's my gauge cluster is broke in my 84 Camaro sport coupe, right now the gauges are two big ones, the right one is speed and the left big one is gas. Three little ones in the middle that are oil pressure(temp?) engine temp and battery. These all just light up to show the amount and do not have a pin.
I was wondering if anyone knows the wires that need to be hooked up for me to get a gauge cluster with RPM instead of gas.
I need a wiring diagram or helps with all of this.
THanks
tylor360
THanks
tylor360
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
IIRC, you should be able to just change out the idiot light switches for gauge senders and swap the gauge cluster in.
Engine: 383 Carb
Transmission: 4L60
Your engine right now has switches installed in it to turn the oil pressure and coolant temperature warning lights on. You'll need to replace them with an oil pressure sender and coolant temperature sender for the gauges.
I think the actual wiring in the car is the same though for gauges or lights. If you get a complete gauge cluster, you can unbolt your idiot light cluster and drop the gauge cluster right in without messing with any wiring.
Engine: 2.8L V6
Ghettobird52
Jul 5, 2024 11:18 PM
