1988 IROC Fog Light Problem
Old Jun 9, 2006 | 09:09 PM
senorcalvo's Avatar
Hey gang,
I'm hoping someone can help me sort through my fog light problem on my 1988 IROC Camaro. I'm not getting any power to the lights and had to temporarily remove them since they have to operate for the car to pass Virginia State Inspection. I tested the lights themselves and they do work so I know they are good. I replaced the fog light switch thinking this was probably the culprit but I still don't have power to the lights. The fog light switch does not seem to be getting any power either, since the green light does not illuminate when switched on. The fuses all look good so I'm not sure what to check next. All suggestions and ideas are greatly appreciated!
Thanks,
M.L.
Old Jun 9, 2006 | 09:49 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
the only things left to check are as follows.
1. The Foglight Relay - It should be located on the drivers side under the hood right near the washer fluid tank. Try replacing this part since it is a inexspensive fix.
2. The Foglight power lead - Wich is located near the relay. it is a wiring clip that plugs into the headlight circuit to get power. The wire colors are green and black. (green is the hot wire, and as usual black is the ground)
3. Wiring - this is the only thing left that could be wrong with them. make sure you check the wires that go in front of the radiator support, as these are the most likley to be damaged because of where they are located.
So from my own personal expieriances with these irocs, The educated guess would be the relay. Those do go bad, The same problem happened with my friends 86 iroc. As it turned out (you guessed it) foglight relay.
So good luck man, and cudos on owning such a nice car.
PM me if you have any more questions,
Zach
Old Jun 11, 2006 | 05:11 AM
senorcalvo's Avatar
I checked the relay and sure enough, it was completely corroded. After replacing it the fog lamps lit right up! Thanks for the expert advice!
M.L.
Old Jul 16, 2006 | 09:15 PM
EMTGuzman's Avatar
Car: 05 Grand Prix / 85 Trans Am
Engine: 305 TPI Bored .030/Cam
Transmission: 700R4 Megashifter
hey guys...
i just went out to check my relay - by any chance are there two mounted in the same places on both sides of the car? I unplugged one and tried the head lights and that side did not pop up. The fog light relay that was given to me by autozone would not fit so i'm not positive i have the right relay.
anyway - just checking. its completely possible the guys at autozone gave me the wrong relay also.
and can someone tell me which fuse goes to the fog lights also - all the labeling on my fuse block is faded off.
Old Jul 17, 2006 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just a side note. What green light?
JamesC
Old Jul 17, 2006 | 06:58 AM
EMTGuzman's Avatar
the green light nextt to the switch on tyhe dash...
Old Jul 17, 2006 | 07:20 AM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I'm not sure about the relay location, but I am sure that if you don't know EXACTLY what you need at Autozone, and you trust the average autozoner behind the counter, you will leave with the wrong part. I think when they hire people, if the applicant can show that he/she knows the average car runs on gas, they automatically start as a manager. To get hired as a redshirt, you just need a heartbeat.
Old Jul 17, 2006 | 07:25 AM
JamesC's Avatar
Are you certain that the light and switch go together. I've never seen one such as you describe (and I have an IROC). Check the pics in the following link:
https://www.thirdgen.org/forums/body...ight=fog+light
JamesC
Old Jul 18, 2006 | 08:23 AM
Car: 87 IROC
Engine: 5.7 TPI
James, ironically in the link you provided, there is another link with a pic of the green light. However, it is not how EMTGuzman described it. In the link, the green light is actually on the bottem of the fog light switch itself, not next to it. Personally, I have never seen such a switch in an Iroc.
https://www.thirdgen.org/forums/at...g?d=1124019898
Old Jul 18, 2006 | 08:34 AM
JamesC's Avatar
No, you haven't seen a switch like that in an IROC. I was remiss in not explaining that what appears to be a green light in the above link is a reflection. Here's better pic.
https://www.thirdgen.org/forums/atta...-out-bezel.jpg
JamesC
Old Jul 18, 2006 | 08:49 AM
Car: 87 IROC
Engine: 5.7 TPI
I was actually wondering about that. After posting, I was looking at that pic again and trying to decide weather or not that was a reflection. It really does look like a light in the picture. Anyway, thanks for clearing that up. Looks like you have a nice, clean driver's area. Regarding the light that Guzman was describing, I, too, have never come across one. Guzman, would you mind posting a pic of your switch for reference? Thanks.
Old Aug 6, 2006 | 11:52 AM
Transmission: WC T5
hey guys, just letting you know 1985-1987 IROCZ had a foglamp switch that didnt illuminate, however 1988-1992 IROCZ + Z28 had a foglight switch that had the same kind of light the defogger had, only a lime green color.
Also, if you want to upgrade to the "green light" you can. This way you actually remember that your foglights are on.... What i did was took the foglight switch out of an 88 IROCZ. took a good part of the harness behind it. brought it home, removed the old one. installed the new harness to the old two wires ( just match the colors) the you run the purple wire to the gauge lights, and the brown one to a power. and VIOLA! cool new green light. FYI i did this swap in my 86 iroc so it definatly works.........
And i'm not sure about the foglight relay in a Pontiac. I will look at my friend 89 T/A and get back to you about that.
-Blue IROC-
Old Aug 6, 2006 | 02:38 PM
JamesC's Avatar
Never seen one. Got a pic?
JamesC
Old Aug 6, 2006 | 06:56 PM
Car: 87 IROC
Engine: 5.7 TPI
Yeah, I'd like to see that as well.
Old Aug 6, 2006 | 07:22 PM
Stephen's Avatar
Car: 87 GTA
hey guys...
'86 and earlier have 2 relays, one per light. 87 up, have one relay on the driver's side by the windshield washer. That's you have 2 relays on your 85.
Old Aug 6, 2006 | 07:49 PM
Stephen's Avatar
Car: 87 GTA
JamesC
My 87 GTA has one...
Old Aug 6, 2006 | 08:35 PM
JamesC's Avatar
Thanks. I'd like to see the IROC version with light.
JamesC
Old Aug 6, 2006 | 08:38 PM
Stephen's Avatar
Car: 87 GTA
According to the ones listed online, never seen in myself, they are the same. Mine has the Off on the left, On in the middle, and the indicator light on the right.
Old Aug 7, 2006 | 05:56 AM
JamesC's Avatar
The IROC switch doesn't look anything like yours (if that's what you're saying). Check the link above for a pic of an IROC switch.
JamesC
Old Aug 7, 2006 | 02:35 PM
Stephen's Avatar
Car: 87 GTA
Yeah, no idea what an IROC one should look like
Old Aug 10, 2006 | 02:39 PM
JamesC's Avatar
http://www.moderndaymuscle.com/inc/sdetail/726
JamesC
Old Feb 1, 2009 | 08:03 PM
bobj823's Avatar
Re: 1988 IROC Fog Light Problem
I am interested in the steering wheel radio button cluster.
Let me know.. deweybeach@comcast.net
Old Feb 1, 2009 | 08:40 PM
87_Injected's Avatar
Car: 2010 2LT RS
Ahh the dreaded Virginia State inspection! One of the reasons I don't live there and my parents still do Sorry... I've had many problems with that state throughout my years of living there and driving. They sure are strict!
Old Aug 24, 2011 | 03:53 PM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
just want to know what the relay looks like I did a lt1 swap and change to the newer relays, and the fog light relay Connector is it a( red connector) with a green and a black wire I found two defferent set of wires a black/ and green with no connector end thank for your help
Old Oct 21, 2011 | 06:34 PM
dustedwatts's Avatar
AWESOME!!! this post has circulated around our parts warehouse for a few days! (parts plus) made us all have a good laugh!!! thx
Old Feb 9, 2012 | 03:58 PM
Andyk13089's Avatar
I am having a similar problem with my fog lights. I thought i would post it here instead of crowding up the board with another fog light thread. I have a 1990 Iroc and when I bought it came without bulbs in the fog lights. I flipped the switch once or twice and the little green light lit up. I finally got around to putting bulbs in the lights and they came on and worked for about 2 minutes. The little green light on the switch no longer comes on which is strange because it is a backlit switch and it still lights up. So did half of my switch go out? The relay looks fine, bulbs are good, and i am about to go crazy.
Old Feb 9, 2012 | 08:28 PM
bobj823's Avatar
I too am having a Fog Light problem but on an 88 Trans Am. When I jump the relay, they light up. But no power to the switch on the dash. I'm running out of places to look. Any ideas ?
Old Feb 9, 2012 | 09:29 PM
55ChevyMan's Avatar
that was the problem with mine on my 86 IROC Z it was located on left side but I was told that some cars had them on right by the battery box
Old Feb 12, 2012 | 04:45 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
hell. i thought all you needed to get a job at auto zone was the ability to work a keyboard and a pretty haircut
Old Feb 12, 2012 | 09:48 AM
55ChevyMan's Avatar
well here we have Advance auto parts and Auto zone and redoing my lt1 heads and for all the replacement gaskets Advance was $25 dollar higher for the very same parts plus I earn points and got $25 from Auto zone so that $50 total I need save on my auto parts I like Auto Zone
jaridjohn
Jul 8, 2024 03:49 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
