Autometer Gauge wiring help!!
Old Jun 12, 2006 | 09:02 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Transmission: 5speed
Ok, I've searched and searched but haven't found anything. It keeps coming up with threads that have no relevance to what I'm searching.
I need to know how to wire a few autometer gauges up. They are:
a) Voltmeter
Auto Meter
b) Oil Press
Auto Meter
c) Water Temp
Auto Meter
Old Jun 15, 2006 | 09:03 PM
TeK-91z28's Avatar
Car: 91 z28 convert
top
someones HAD to have done this!
Old Jun 16, 2006 | 07:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I think that most people who reads this are not responding back bacause it sounds like you are not wanting to read the directions that came with the gauges or research the directions on auto meters website. These are easy gauges to hook up. Are you replcing the OEM gauges or just adding these gauges inside the care? The volt meter just needs a 12v ignition source. I run my temp gauge right off the sender on the drivers head. take a peek at the instructions for the pressure gauge and see of you can tap into the stock sender or if you need to add one.
Old Jun 17, 2006 | 12:03 AM
zrated57's Avatar
I read somewhere that you should use the sender that comes with the gauges because the stock senders provide a different voltage than the autometer sender.
Just a thought.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
