simple enough electrical problem could be a big break PLEASE HELP
Old Jun 22, 2006 | 10:35 PM
Italiantank48's Avatar
Car: 1988 Chevrolet Camaro
Engine: 2.8 v6
ok, how do I replace the TPS plug, not the sensor, but the little 3 pronged plug that goes into the side of the sensor? I took a look at it since I really don't think my TPS itself is busted, and one of my prongs looks... melted. and since i've had so many mysterious and oddball problems with this car, I'm thinkin this might be a case cracker.... step by steps and where to buy the little plug thing would be much appreciated!!
Old Jun 22, 2006 | 11:34 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
go to the junk yard and look for a six cylinder or a tuned port car and simply cut the connector off.(i believe the six cylinders plug will work) you can also get one off a 3800 motor from a oldmobile delta 88, 98, buik le sabre, baisically anything with the old 3800 motor in it. this motor should have a trim plate saying tuned port injection on it but somtimes the plate is removed. i dont think the series 2 3800 motor will have the connector you are looking for. after that cut off your connector. trim off the wire insulator on both you wires and the connector that you just got's wires. get some wire shring wrtap(this is the best way but electrical tape will work if you cant find any shrink wrap) if you find the shrink wrap make sure it is big enough to encompase the wires plus the solder you need to use to do this wright. the shrink wrap is heatr sensitive and will shrink around the wire when heat is applied to it. a blow drier works best.(you have to slip on the shrink wrap befor joining the wires. flatten out the strands of wires and insert them into eachother(like putting your fingers together) after that solder them together. this is the appropriate way to repair wires. you could aways twsit the together(i dont reccomend that) or you can buy male femail connectors and simply insert the wire into the connectors and with a crimping tool(no pliars wonmt work) cripm down the connector to the wires and plug themn together(if you do it this way id suggest buying the ones with the plastic around the connectors so they will fit together and not get a lot of water and what not on them. after all that it should work.
hope this helps
good luck
sean
Old Jun 23, 2006 | 12:23 PM
Vader's Avatar
Or get a new replacement connector/pigtail from a parts store and solder/heat shrink the connections as suggested by Green89 to avoid future problems. Skip the compression or crimp connectors unless you want more problems later.
Old Jun 23, 2006 | 10:40 PM
Engine: 383 HSR EBL
i didnt know you could purchase that connectorat a parts store.
Old Jun 23, 2006 | 10:44 PM
Engine: 2.8 v6
yea... bought the parts - it was a pain in the @$$ cuz I hadn't yet checked these messages and opted not to skip the crimp styling. it wasn't the problem.. if you're curious about how the problem really currently is and you want every bit of information i can give you then go to the engine tech area and look for something like you are a god if you solve this... it's all in caps... frustrated i am... talk like yoda i do...
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
