HELP! CHOKE LIGHT/LOW VOLTS AFTER WARM-UP
Old Jun 25, 2006 | 05:24 PM
1986camaroguy's Avatar
I'm new to this site and need some help. After start-up choke light goes on and volts drop significantly. Car doesn't want to stall unless i have some accessories on. Alternator reads 12v. Any help on this would be great. thanx guyz car is 86' 305" auto
Old Jun 25, 2006 | 06:59 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
If that 12 volts is checked when running I would say you have a charging system problem...alternator/battery?It sounds like the alternator isnt charging and starting to die cause it can't run on battery voltage alone.
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
