electrical problem need help asap
Old Jul 18, 2006 | 12:54 AM
mcleve10's Avatar
Car: 1991 Camaro Rs
Engine: 305 HO
so i just bought a 92 rs a few days ago and today all of a sudden the power door locks, trunk switch dome light and passenger side window switch stopped working. any ideas? i tried fuses but that wasnt it. i jsut dont want to go to a mechanic and have them charge me some bs.
Old Jul 18, 2006 | 02:32 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The cigarette lighter on 90-92 Camaros came with a factory defect. When you use it the fuse blows. I found a diagram on another post. Fuse 11, a 20 amp. Most likely this is your culprit.
Attached Thumbnails electrical problem need help asap-fuse.jpg   electrical problem need help asap-fuse2.jpg
Old Jul 18, 2006 | 02:39 AM
mcleve10's Avatar
Car: 1991 Camaro Rs
Engine: 305 HO
well that about sucks seeing as how i use my radar everyday. anyway to fix it? cheaply
Old Jul 18, 2006 | 02:45 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
The socket is usually not the problem. The element itself will apparently cause the fuse to blow when pressed. Easy fix, replace fuse and don't push in the cigarette lighter. Better fix, go to the dealer and buy a new lighter element. They supposedly revised the part and all replacements are of this variety. This has come up before try a search, something will come up.
92GTA
Apr 9, 2016 07:39 AM
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
