Wierd Problem
Old Jul 23, 2006 | 10:09 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Wierd Problem
Just had this happen and Im not sure what to do. I go to start the car and I get nothing. So I figured the battery died, I tested it and it was ok. I checked the alternator and it was ok. I just installed a new starter and its been working for about 4 months. I go and try to start the car 2 minutes later and it will start right up with no problems. But, my radio will tuyrn on and off like its losing power. I didnt change anything electrical recently. I checked all the wireing under the hood just to be sure nothing rattled loose. I dont know what else to check or if this is a easy fix problem. Any suggestions? Thanks
Steven
Old Jul 23, 2006 | 11:14 AM
Vader's Avatar
I'd suggest that you check the connections at the starter, including checking the fusible links connected there. It sounds like an intermittent connection.
Old Jul 24, 2006 | 12:17 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
I just realized I tested the alternaotr wrong. I tetsed it with a voltmeter not a load tester. So Im gonna check it again tomorow and hopefully its that simple lol Thanks Vader
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
