Battery relocation project, anyone done this?
Old Jul 24, 2006 | 10:56 AM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
This is relation to my third gen LT1 car but is the same for the 4th gen as well. I originally was just going to move the battery from the factory location on the passenger side to the drivers side so I had a neat, roomy spot to mount the LT1 computer. After doing some measurements I decided the drivers side wasn't going to work either as it would be in the way of my CAI set-up. I went ahead and got a battery box from work, same thing as the one from Summit but mine was free, went to Advance and had 18" ft of #1 gage battery cable cut, ( It's the clear kind with the copper wire, looks neat ), got my hardware and negative cable from work too so they were free :devil: , made my measurements and started putting all this together. The box is made of black plastic and is made for the Optima batteries, which I have a brand new red top, and has all the hardware to mount it to the car. I was going to install a power cut-off switch as a extra precation to prevent theft but thought cutting power to the computer might mess something up, I'm not sure if it would or not though. This works great for me because my 87 camaro has a locking stowage compartment in the rear which hides the battery, cables, nitrous bottle and hardware. I'm still able to put the t-tops in the bags and get to everything, it's working out great. Anyone got any pics of their set-up if this has been done? I'll get some pics up as I go along by Friday.
Old Jul 25, 2006 | 01:23 PM
9ronone's Avatar
Car: 88 Iroc; 98 ZX9
Engine: TBI350; 998cc
Transmission: 700r4; 6speed
Axle/Gears: 3.42posi; several sprocket sets
I moved mine to the storage compartment where the spare tire used to be. Using 0/1 cable with a 300 amp anl fuse right next to the battery and a 250 amp breaker under the hood on the driver side strut tower. That way the wiring is protected at both ends in case of a short. Any time I want to cut power to the car's electrical system, I just have to hit a button on the breaker to trip it. The storage well in the rear wouldn't work for me to mount the battery due to the sub box. It didn't seem to help traction any, but it does clean up a fair amount of space under the hood.
Old Jul 25, 2006 | 05:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BATTERY UP !
Originally Posted by 98_LS1
............. thought cutting power to the computer might mess something up..........
You CAN have your bat-cut-switch AND
keep the comp hot. Here’s how:
Wire the bat-cut-switch per normal.
Then run an additional wire to the comp
from the bat directly.
Use a fuse for this new circuit of course.
Happy Racing !
— If people drove any slower
they’d be going backwards —
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
sahlomonic
Sep 20, 2015 07:15 PM
89newfun
Sep 16, 2015 09:28 AM
gta892000
Sep 16, 2015 12:37 AM
