fog lamp relay ground
Old Jul 31, 2006 | 02:04 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
does the relay need to be grounded? if so, is the metal bracket how it is grounded? i got a new one today and the bracket on the relay is plastic and the fog lights don't work. the fuse is good, the switch works....but the voltage at the plug for the fog lamps reads negative 13.xx??
Old Jul 31, 2006 | 03:51 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
negative readng means you have the probes backwards...
Old Jul 31, 2006 | 11:48 PM
eagle_eyes's Avatar
Engine: '93 LT1
the probes only fit one way...unless you are referring to the multimeter....i put the black to the black on the fog lights...which diagrams label as ground, and i put the red to the purple
Old Aug 2, 2006 | 11:50 PM
eagle_eyes's Avatar
Engine: '93 LT1
anyone?
Old Aug 3, 2006 | 12:58 AM
Stephen's Avatar
Car: 87 GTA
The relay gets it's ground through the wiring, not the mounting tab. If you're there anyways...
Did you knoe, your fog lights don't work when the high beams are on?
AustinThirdGen.Org » Content » Tech Articles » Making your fog-lights work regardless of high and low beams
Took me 10 min, 1 handed! Those with 2, could easily do it in less than 5 min.
Old Aug 3, 2006 | 11:23 AM
eagle_eyes's Avatar
Engine: '93 LT1
tried with and without high beams...also, the wiring diagrams i have show 4 wires at the switch....i have 5?? yellow, brown, black, purple,.....and gray?
BumpaD82
Feb 26, 2016 02:57 PM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
sbrandon
Sep 9, 2015 07:31 AM
Gunsbee
Sep 7, 2015 07:10 PM
