Hey what's this wire for??
Old Aug 2, 2006 | 08:31 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
I replaced my a/c compressor today. My old compressor has an electric plug on the back, as well as a two prong plug on the a/c clutch. The new compressor replacement doesn't have the plug on the back. Now the clutch won't engage and suck in my new freon. Anybody know what this is and if it could be causing the clutch to not engage?
Old Aug 2, 2006 | 08:54 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
high pressure cut out switch. yes it will prevent the clutch from coming on. you will need to transfer it from the old compressor. empty the refrigerant remove the snap ring and pull the switch out. Mike
Old Aug 2, 2006 | 08:59 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
this guy knows what hes talking about!
Old Aug 2, 2006 | 09:01 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
whats neat is that it also looks like a knock sensor plug and also like some of the thermostat housing mounted temperature sending units for the ECM
good luck
Old Aug 2, 2006 | 10:01 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
That's it, thanks!
Infested
May 22, 2018 11:56 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mx127
Aug 10, 2015 08:13 AM
