Brake Light/Turn signal Problem Already Searched...
Old Aug 3, 2006 | 07:19 PM
87'z28gpse's Avatar
Car: 1987 Iroc
I'm having a problem with my 88' GTA. The problem is that the pass. side brake light and turn signal don't work. When I turn the parking lights on everything lights up as it should, but no right turn signal or brake light. The turn signal indicator lights up steady in the car. I have replaced all the bulbs front and rear. Also, I have checked the fuses and everything is fine. Any help is greatly appreciated. Thanks
Old Aug 3, 2006 | 07:34 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
RELAY maybe, search for diagrams in the electrical board.
Old Aug 3, 2006 | 07:38 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
are the bulbs in properly? my friend had the same problem with his car and it turned out that the bulbs were in backwards or something
Old Aug 4, 2006 | 08:54 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
nah check the base for the bulb. My old 88 Bronco had the same issue, started with simple stuff like the bulb and being an electrician I checked the wires..... only to find a bad base.
Besides they're cheap enough for trouble shooting purposes
www.myspace.com/nickjcolletti
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Fronzizzle
Aug 9, 2015 01:15 PM
