HELP!!! PLEEEASE!!IM CURSED!!!! HELP!!!!!
Old Aug 12, 2006 | 12:11 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Situation:
This night was so totally wasted, I was going to take my girlfriend to the movies and told her I was going to take my Camaro to pick her up at around 8:30 pm. I get to her house go inside wait for her, we then get back in the camaro ready to go, then when I turn the key to turn it on it fires up and dies instantly, I then attempt this several more times and it just keeps doing the same thing, firing up and shutting down. I did not attempt anymore because the neighborhood she lives in is kinda...quiet and she lives in a canyon and my starter and engine echo'ed all across the nieghborhood with every attempt. As of now the Camaro is stuck in the front of her residence, I hope her dad doesnt get mad.
Situation and Speculation
So I just recently repaired the probable causes of my car, As many of you read on my previous topic/s, I changed my ignition lock cylinder and in doing so it did not correct the problem that I thought it was. What I thought was the ignition cylinder became worn and unfunctional because when I would turn the igniton to the ON position the guages did not turn on neither did the lights on the cluster or the sound, it just gave power to the windows and the cargo light and mirror lights. And when I replaced it with the NEW ignition lock cylinder it still does the same thing,shortly after completed installation of the lock cylinder the same thing happend as the original. Now as soon as I bypassed VATS,and the starter relay it would fire up and then die, I would have to sometimes crank it a few times till it idle'd. Now this has been continous since that day (about a week) Now it will not idle, it just turns over fires up and then dies instantly. What I have noticed ever since the beginning, is that when I hold the igntion key (while on the ON position) if I hold it to the right real stedy and keep it there it stays on, and idles but when I release it it turns right off, Im having doubts that it is something else rather than the ignition lock cylinder, surely a brand new lock cylinder cannot be the cause of this, since the original did the same.
Action Taken:
I checked the Fuel Pump, I hear hums,whzzz,sounds of that type.
I checked the injectors theyre getting fuel and releasing it.
I checked the spark plug wires and the cap for any loose or disconnected wires, all were properly in thier functioning and correct order.
Checked for Vaccum leaks, none found.
Checked for any loose battery cables, or cables leading to the battery, nothing out of the ordinary was found.
I checked under the steering column for loose wires and specifically wires that I had connected to bypass the starter relay, all seemed intact.
I checked all electrical components that I could see I had my 1 millionpower flashlight this was at about 9:00PM friday night (tonight) everything looks intact and functional.
Question:
What could be wrong with it? Could anyone make any logical or any guess for that matter that could cause a phenomenon like this!? Please help me!!!!
Old Aug 13, 2006 | 01:03 PM
Vader's Avatar
Your new lock cylinder is probably fine. The ignition switch itself is suspect.
Old Aug 13, 2006 | 01:32 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
thats what i was going to say. look under youyr colum. turn the key.. see that rod that moves? that is your ignition switch. you may have to lower your column to get it off, once off oporate it manualy (screwdriver or somthing) and if the problem continues replace that unit. they are only about 30 bux IIRC.
Old Aug 15, 2006 | 07:21 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Thanks fellas! it was the igntion switch! it was hard to get to it... but after bringing the right tools and enduring 99+ heat with no shade! and my bueatiful girlfriend providing me refreshments, I was able to install and fire up the car in a few hours!!!
oh and a call from bigbabylouz28...helped me position the ignition switch
Old Aug 17, 2006 | 04:44 AM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
that would have been my 1st guess too, i guess working at an auto parts store is paying off lol, ppl come in and buy ignition switchs commonly.
Old Aug 17, 2006 | 05:15 AM
Vader's Avatar
Originally Posted by Psycho_91Camaro
T... and my bueatiful girlfriend providing me refreshments...
This post is useless without pictures.
FormulasOnly
Sep 6, 2015 10:42 AM
dimented24x7
Mar 10, 2004 04:54 PM
fast86z28
17
Apr 8, 2003 10:26 AM
thunder87
Jul 31, 2002 04:28 PM
RealDeal
May 1, 2001 01:02 PM
