wiring question
Old Aug 15, 2006 | 04:23 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
wiring question
ok so i am finishing up my swap. and have 8 wires i need to splice into certian things to make it all run.
i need to splice into a cranking signal. i have a manual so i want to use the clutch position sensor too. where is a good place to splice into this?
a/c request. i have no clue? the computer just needs to see that its on so it bumps up the idle. i dont know where to start on that one?
where can i splice into the back up lamps at?
where can i splice into the fuel pump at?
and a 12v switched needs to have power on both run and start.
i would like to splice these connections on under the dash. if you have any suggestions let me know please thank you.
Old Aug 15, 2006 | 04:41 PM
Barry 85IROC's Avatar
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
You need to get theshop(GM) manual for the car w/ the factory wiring diagram. This will be a tremendous help.
Old Aug 15, 2006 | 09:48 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
well thats easy enough i work for a dealer. im actually a tech in training. wiring is not my strong part. lol i can build engines but cant wire to save my life. lol
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
